nevermind. sorry i asked
Elevated AC heaters?
No, it means exactly connecting the heater center tap to a DC voltage. The AC across the winding is unchanged, the heaters still see 6vAC, but now it also sets 10v above ground. Just like the signal AC on the plate of a tube is sitting at 200v DC as well.Education is what you're left with after you have forgotten what you have learned.
On the valve wizard site it shows the DC taken from the HV in the top image below thru a voltage divider and has a cap. If i use a 220k on the top and 10k on the bottom (3 watt resistors?) will that be workable? And if so, what about the cap, can i use a 50 or 100uf ? The voltage at say the PI node is around 300v i believe so that divider would = around 13v.
Originally posted by daz View Post(3 watt resistors?) will that be workable?
Do you know the equation for calculating power dissipated by a resistor?WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
