Elevated AC heaters?
  • Elevated AC heaters?
    nevermind. sorry i asked
    Not resistance, voltage. Lift them to +10 or +20vDC.
      What is elevated AC tho? (which i have heard mentioned in my search) Does elevating AC mean changing it to DC?
        No, it means exactly connecting the heater center tap to a DC voltage. The AC across the winding is unchanged, the heaters still see 6vAC, but now it also sets 10v above ground. Just like the signal AC on the plate of a tube is sitting at 200v DC as well.
          On the valve wizard site it shows the DC taken from the HV in the top image below thru a voltage divider and has a cap. If i use a 220k on the top and 10k on the bottom (3 watt resistors?) will that be workable? And if so, what about the cap, can i use a 50 or 100uf ? The voltage at say the PI node is around 300v i believe so that divider would = around 13v.
            Is this going to be another multi-page thread about Electronics 101?
            Do you know the equation for calculating power dissipated by a resistor?
