Hi All.
I have a high gain amp that puts out 516 VDC on the plates and 511 at the screens. It is an EL34 based amp so screen resistors are 1K 5W. I have popped a few tubes in the last year, never the same position (tubes are losing vacuum, turning white) and someone mentioned that running the bias at 70%, with current producton tubes and with these voltages, very well may be too much. I play a lot - probably some 30+ hours per week.
So let us assume this is true for the moment, the only tubes I can even find that are close to accepting 510VDC on the screens are the TAD EL34B-STR (claiming 500 VDC on screens max). Shuguang I guess? I have a set of these in a plexi and I find that they sound fine.
The transformer is custom made and similar to PT for a SLO100, so it's a 360-0-360.
The question is should I have a new tranny made, something that will yield something a bit less like 340-0-340??? Or should I put a dropping resistor after the rectifier circuit? Or is there a set of tubes out there that will accept a bit of abuse in this area (by your experience)? Or even perhaps raising the screen resistors??
I have used JJ E34L for the last decade and a half... But after popping two of them some months back, I bought a set of Tung-Sol EL34s... it was about a month going before I lost one about a week ago. Again I assume they are losing vacuum because they are turning white above the getters.
My temperature probe says the tube's surface runs at about 280 degrees F. But damn does it get HOT in the room.
Thanks for any input you may be able to offer.
Thanks.
Thanks.
