Hi all... you might remember this beauty from the "Repair and Restoration" section ![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
http://ampwares.com/schematics/100W_...F_Twin_Rev.pdf
[you can skip this section if not interested in the backgroung of this specific amp, but some things could be of use for people dealing with Fender Twins]
This amp is pretty much to standard with the exception of:
- PULL SWITCH distortion function has been removed
. all long wires going from the MASTER VOLUME to several sections of the board
. 12M + .o1 uF + 12 K associated to the distortion function (see post #455 for historical details details: LINK)
- REVERB signal feed increased (see post #359 point #4: LINK)
- Added an ADJUSTABLE BIAS VOLTAGE TRIMPOT (LINK)
- just in case, also DEATH CAPACITORS removed and a three prong cable added
So, the idea is to see if I can use the (now unused) GROUND SWITCH at the back of the amp to have three levels of PRESENCE:
- NONE
- MID
- MAX
I've been "cultivating myself" and understood that I need to play with
- NEGATIVE FEEDBACK Resistor (820 Ohm in my Twin)
- PHASE INVERTER tail resistor (33 KOhm in my Twin)
- NEGATIVE FEEDBACK tail resistor (100 Ohm in my Twin)
![](https://i.ibb.co/0JKBPny/1-Components-identification.jpg)
What I've understood from the 5F6A Fender Bassman circuit is that:
- 100 Ohm resistor needs to be replaced by an RC arrangement
![](https://i.ibb.co/R7KgBTc/2-fender-5f6a.jpg)
- the value of the 820 resistor needs to be recalculated to maintain the same voltage divider ratio
originally 820/100=8.2 and now X/4.7K=8.2, then X=39 KOhm
- the value of the 33K resistor needs to be decreased by 4.7 K (R value with the potentiometer at 0), then 28 K
Now, from the three settings (NO PRESENCE, MID and MAX) the two fixed R values at the extremes are clear:
- NO PRESENCE: 4.7 K
- MAX PRESENCE: 4.7 K + 25 K = 30 K
QUESTION #1:
what is the MIDDLE setting based on?
a) Half way of the the potentiometer turn (12.5K if it is linear)
in that case it's 4.7 K + 12.5 K = 27 K
b) the RESISTANCE that provides the middle value of the voltage divider ratio between the NO PRESENCE and MAX PRESENCE values?
RATIO= 8.2 at NO PRESENCE setting
RATIO= 39K/(4.7K+25K)= 1.3 at MAX PRESENCE setting
Middle value (8.2+1.3)/2= 4.75
So the resistance value 8.2 K
QUESTION #2:
do you guys see a way to use the 3 position GROUND SWITCH to do this? (I have not gotten my head around this yet for some reason)
![](https://i.ibb.co/SxMLrXy/3-three-way-switch.jpg)
thanks!
- NONE
- MID
- MAX
QUESTION #1:
QUESTION #2:
thanks!
