egnator Tweaker 15 Needs a little more gain
  • egnator Tweaker 15 Needs a little more gain
    Hi all
    I have been asked to get a little more gain out of this amp. 6V6GT version with the 510R cathode resistor I know that some came with 220R but they would burn tubes out early. currently running at 85% , room get it a little hotter
    Egnater_tweaker_15.pdf
    But my main question, Is there anything i can do with V1 stage that can add a little more gain
    I can see there is a fet stage before V1.
    Let me know your idea's
    R20 and C23 are marked "np" which I assume means not populated. You could try fitting say 1k and 22u in those positions.
      Thanks dave I'll check tomorrow to see if they are or not fitted
        Morning changed the bias resistor from 510R to 280R now got 95% plate dissipation . fitted the 1k and 22uf and there's a little more.
        not sure if its going to be enough... we shall see.
          For even more gain, replace R20 by a short.
            thanks i might try that,
              https://el34world.com/Forum/index.php?topic=22569.0
              FET preamp stage question...
              FET Cascode Preamp - Blue Guitar.pdf
              https://www.circuitstoday.com/cascode-amplifier 1)
              It's All Over Now
