Modifying a JMP1c to sound brighter. Noob questions
  • #31
    I think what bruzanhd intends is a voltage divider to simulate the channel mix circuit in a plexi type design.
    correct, here is a picture of the traces on the back. Any thoughts with this in mind? The ground from the volume pot is quite far on the board so i'd have to do some flying leads or something which i'd like to avoid if possible. they both end up grounding at the same pcb pad though
    • #32
      Seems ok to me. What ever resistance is on that short trace isn't going to cause an audible ground loop. Better than most vintage amps really.
      • #33
        Thanks for your insight, I just wanted to make sure I wasn't making an obvious mistake. I will try it out tomorrow and see how it goes.
        • #34
          Well I did it, along with the bright cap and the presence mod. REALLY digging the sound I'm getting. I have a mild concern:
          When the guitar volume is turned up and my hand is on the bridge of the guitar (or any grounded part) it still has some hum. When I roll the guitar volume to zero, the amp is silent. Is this expected behavior or am I experiencing a ground loop. As a side note, the amp has always done this although now that I'm hyper focused on it seems maybe louder? Although this may also be because I have made the amp allow more high end through.
          Edit: Using my pedal board between the guitar and the amp lessens the hum. Does it seem like the noise is mostly the fault of my guitar I dont have another to try it with?
          Edit 2: The hum peaks at 540hz. I wonder if I may just have low quality power in my home.
          Here is some pictures of my work. Tell me if you see a problem or an improvement I should potentially consider.
          Click image for larger version  Name:	ground1.jpg Views:	0 Size:	1.54 MB ID:	997780 Click image for larger version  Name:	ground2.jpg Views:	0 Size:	978.2 KB ID:	997779
          Thanks again for all the expert advice you all have been giving me.
          • #35
            Great.
            Does it seem like the noise is mostly the fault of my guitar ?
            Yes, because of this:
            You might have a noisy environment.
            I distrust sound analysis/measurement using a phone
            • #36
              Great.
              Borrowed and Tried another amp it and does something similar. I think it’s settled, guitar picking up environmental noise.
              • #37
                Okay so now that I’m driving my self nuts about every little noise, is mechanical noise from the amp somewhat normal? My amp makes a low constant hum (240hz?) from the actual amp. Not through the speaker. So it’s a physical vibration somewhere. My guess is likely the power transformer but really I don’t know. It very well may have always done this and it’s a normal behaviour but I haven’t really paid attention before.
                • #38
                  240Hz wouldn't sound like hum. More like a note just a tad sharp of A#3. I've never heard this phenomenon myself. It seems worth mentioning that it could be a harmonic of 120Hz. Does it dampen if you put your hand on the power transformer?
                  • #39
                    Finally got around to tearing down the amp again and snugging up some screws. I just took everything apart and re seated and re snugged everything. Sound is mostly gone now. It still has a quick vibration when I switch the amp on but at idle it's a little quieter. Still couldn't pin point the source. When I put a small pressure on part of the chassis the vibration would change pitch. But i could apply that pressure anywhere and get the same effect. And just to clarify this sound does not come through the actual amplifier's output. It is purely physical vibration. If I run the amp with all knobs on zero and speaker disconnected the sound will be there.
                    • #40
                      Hello folks I kinda finalized the mods, was fighting with getting the right amount of gain since I tightened up the response, so I ended up increase the gain in the second stage, and adding a shade more low end onto the bass control. Sounds great. Here's an annotated schematic. I have a question of best practice though, I have an unused triode in the middle of the amp, is it best to leave it floating or should I ground the plate, grid and cathode directly? The heaters are DC and the lines are run on the PCB so I can't disconnect it. Right now it is floating but maybe this is a bad idea? Maybe it doesn't matter. Thoughts and opinions appreciated.
                      Click image for larger version  Name:	JMP1_bruzanhd_no_boost_annotated.png Views:	0 Size:	58.7 KB ID:	1001934
                      • #41
                        Leave it floating
                        As it stands the mechanical parts in the tube are just that. No electrical significance. If you ground anything then you have parts that can present a "voltage differential". A differential can become part of a circuit and that is what you don't want from an usused triode.
                        • #42
                          Leave it floating
                          Thank you, this was my intuition but I started reading all kinds of crazy schemes and ideas about it.
                          Deneme bonusu veren siteler
                          betticket istanbulbahis
