Originally posted by Chuck H
View Post
Modifying a JMP1c to sound brighter. Noob questions
Seems ok to me. What ever resistance is on that short trace isn't going to cause an audible ground loop. Better than most vintage amps really."Take two placebos, works twice as well." Enzo
- Likes 1
Originally posted by Chuck H View PostSeems ok to me. What ever resistance is on that short trace isn't going to cause an audible ground loop. Better than most vintage amps really.
Well I did it, along with the bright cap and the presence mod. REALLY digging the sound I'm getting. I have a mild concern:
When the guitar volume is turned up and my hand is on the bridge of the guitar (or any grounded part) it still has some hum. When I roll the guitar volume to zero, the amp is silent. Is this expected behavior or am I experiencing a ground loop. As a side note, the amp has always done this although now that I'm hyper focused on it seems maybe louder? Although this may also be because I have made the amp allow more high end through.
Edit: Using my pedal board between the guitar and the amp lessens the hum. Does it seem like the noise is mostly the fault of my guitar I dont have another to try it with?
Edit 2: The hum peaks at 540hz. I wonder if I may just have low quality power in my home.
Here is some pictures of my work. Tell me if you see a problem or an improvement I should potentially consider.
Thanks again for all the expert advice you all have been giving me.Last edited by bruzanhd; 04-18-2024, 09:18 AM.
Originally posted by bruzanhd View PostWell I did it, along with the bright cap and the presence mod. REALLY digging the sound I'm getting.
Does it seem like the noise is mostly the fault of my guitar ?When I roll the guitar volume to zero, the amp is silent.The hum peaks at 540hz. I wonder if I may just have low quality power in my home.
I distrust sound analysis/measurement using a phone
Great.
Yes, because of this:
You might have a noisy environment.
- Likes 2
Okay so now that I’m driving my self nuts about every little noise, is mechanical noise from the amp somewhat normal? My amp makes a low constant hum (240hz?) from the actual amp. Not through the speaker. So it’s a physical vibration somewhere. My guess is likely the power transformer but really I don’t know. It very well may have always done this and it’s a normal behaviour but I haven’t really paid attention before.
240Hz wouldn't sound like hum. More like a note just a tad sharp of A#3. I've never heard this phenomenon myself. It seems worth mentioning that it could be a harmonic of 120Hz. Does it dampen if you put your hand on the power transformer?"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View Post240Hz wouldn't sound like hum. More like a note just a tad sharp of A#3. I've never heard this phenomenon myself. It seems worth mentioning that it could be a harmonic of 120Hz. Does it dampen if you put your hand on the power transformer?
Hello folks I kinda finalized the mods, was fighting with getting the right amount of gain since I tightened up the response, so I ended up increase the gain in the second stage, and adding a shade more low end onto the bass control. Sounds great. Here's an annotated schematic. I have a question of best practice though, I have an unused triode in the middle of the amp, is it best to leave it floating or should I ground the plate, grid and cathode directly? The heaters are DC and the lines are run on the PCB so I can't disconnect it. Right now it is floating but maybe this is a bad idea? Maybe it doesn't matter. Thoughts and opinions appreciated.
Leave it floating
As it stands the mechanical parts in the tube are just that. No electrical significance. If you ground anything then you have parts that can present a "voltage differential". A differential can become part of a circuit and that is what you don't want from an usused triode."Take two placebos, works twice as well." Enzo
- Likes 1
