What to do with the unused pins on half of a dual op amp?
  • What to do with the unused pins on half of a dual op amp?
    Hi all. I need to use only half of the 4558 dual op-amp. What should I do with the pins on the unused other half to avoid problems?
    Thanks a lot.​​
    Ground the Plus input and connect the Minus input to the output.
      True, but if you are using it with split supply.
      If single supply, connect +IN to Vref.
        Thank you so much!​
