Tube sockets that jingle
  • Tube sockets that jingle
    Since the only way to get parts is online anymore I can't physically inspect any prospective purchaces. So if anyone knows of some good sturdy, tight nine pin sockets I would appreciate the info greatly.
    It seems that most nine pin sockets jingle/jangle. At least the ones I've bought. In this case (they are already installed and I don't intend to remove them) could I just squirt a blob of silicone on them or something? Any tricks?
    FWIW I will be playing my amps that jingle through the holiday season
    TIA
    Chuck
    Silicon might well do the trick, or it might dissolve with the heat in that neck of the woods. I find that when the tubes are inserted, the socket pins tighten up, esp if I 're-pre-tension' them.
    On octal sockets where there are unused pins that I am also not using for anchoring grid resistors 'other' ends to, I take the pin out to stop the rattle - but I find the Belton ones generally rattle less than the ceramic style ones.
      I also find ceramic sockets a more loose and rattly than molded ones.
        Thanks. I've always used the ceramic sockets because they "seemed" better. That and when I first started doing this stuff I had a problem with an amp whose molded octal socket had an arc and went conductive. But there are plenty of Fender amps out there still working so I guess it's not a common issue.
        The problem isn't loose pins. The sockets themselves are loose in the mounting ring.
        Any molded brands that are known to be nice and snug? I like to omit "tube keepers" when I can.
        By the way, what are they made of? They look like Bakalite.
        Chuck
          The ones I get are newbies, and it looks like some kinda hi-temp resistant plastic
            I have a little Gibson GA15 1x10" combo. It melted the power tube sockets (under warranty) so I got Gibson to send new sockets to a local repair shop and they installed them (had to go to an authorized repair shop to get the 'free' sockets...of course they confused pin 1 for pin 9 and didn't bother to solder pin 1 since it is unused...so my amp had no solder connections on the screens..I fixed that and I'm digressing).
            In any case, the new ceramic power tube sockets rattle like you wouldn't believe. I've almost covered them with High Temp Silicone but it didn't really help. Inserting the tubes doesn't 'tighten' the pins enough to matter...they still rattle.
            I don't have a cure and if done right maybe the silicone would work but I just wanted to chime in and say that the silicone-job didn't work in my amp. EDIT: and it looks like shit and I hope I never have to go back in there.
              I will share a secret with you guys. Don't tell anyone.
              Antique Electronic Supply, part number P-ST9-213MX
              NOS military sockets still in the military packages, very high quality, no jingle.
              They cost more but it's all I will buy, I order extra every time to stock up.
              Alby.
                Thanks all.
                Alby, This design will probably be manufactured. So I'll need a socket thats still being made. But, since the P-ST9-213MX comes with such a high recommendation I may use them for these two amps I'm working on. I have a deadline on the proto's and I can't afford random problems. I can take time to find a more repeatable part to spec later.
                Cheers
                Chuck
                casinolevant levant casino
