a fellow recently give me some stuff that I am trying to sort out one is a power transformer that looks brand new marked 710-4149-01 5246220. it has 1 blk lead 2 red, 2 yellow, 2 grn, 1 yel/blk, 1 red/yel, 1 grn/yel am I missing a blk primary lead?
transformer confusion
What's the Blk/yel?
Could be a 5VAC centre tap, measure resistance to the yellow wires, should be less than one ohm. If it's more, see what you have you have from blk/yel to the other wires...long shot but it's possible that blk/yel could be the other primary?
Check out the color codes on these web pages
http://www.el34world.com/Transformers/fentrans.htm
http://www.el34world.com/Transformers/marshall.htm
Is the 1 yel/blk wired together with the black?
Usually the wires to the input go on one side, and the outputs on the other.
The next step is to check the resistance to see if they are paired.
Then use a 10 volt AC wall wart on the primaries and measure the outputs.
It might be something like this one
See the birth of a 2-watt tube guitar amp - the "Dyno Tweed"
http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html
