I've got a prototype amp built which uses a Marshall 1987X preamp and PI and some output tubes which only want to see about 250V on their plates, but require almost as much grid drive voltage as a normal EL 34 amp to clip. At the moment, I've got a transformer which puts out almost exactly 250V rectified B+ (two diode, full wave with a CT) at and I have a smaller power supply "stacked" on top of that to get the preamp/PI voltages up where they'd be in a stock 1987X. It works OK and sounds quite nice, but I'm looking for a more elegant solution.
Here are my thoughts:
1.) Just design the power supply to start with a 400V B+ and regulate it down for the output tubes. (Too complicated, might make the supply too stiff?)
2.) try to redesign the preamp and PI to work acceptably well at lower voltages. (With the main B+ at 250V, after the add'l filtering, I doubt I'd have much more than 200-220V B+ for the PI.)
3.) Add a second pair of diodes & cap to the power supply and generate a B- rail. Add add'l R-C filtering stages to get the B- down to -150V or so. Run my preamp and PI cathode/tail resistors to this supply. Would this work?
4.) Derive the preamp voltages from a voltage doubler which can share the main B+ transformer winding with the power amp? (possible?)
5.) Find or commission a transformer with multiple secondary windings which will suit my needs. Where??
6.) Leave it kluged the way it is with two power transformers.
Your opinions, gents?
Nathan
Nathan
