best designed single tube reverb
  • best designed single tube reverb
    hi everybody,
    i'm using merlins new book to help design an amp. great job on the book and the web site btw but he hasn't gotten to rv yet so i'm asking yall to give me your opinion on the best ecc8 x direct drive rv driver/recovery if such a thing exists. i understand everything but impedance and it is extremely irritating.
    thanx gents
    a recent conversation,
    ..."why not just buy an amp?".. 'cause I'll just have to tear it apart and fix it anyway.
    Hiya mr.jetski
    Have a look at some of teh one-tube reverb circuits over at the Dumble forum. tubenit does quite a few of these in his amps, so it might be worth PM-ing him
      Hi,
      There is some discussion of direct drive reverb on my site: The Valve Wizard
        thanks pete and merlin
        just at first glance can't a ecc81 do the same job with half a bottle @ 10k ra?
          Originally posted by tubeswell View Post
          Hiya mr.jetski
          Hi,
          would you mind to give a link?
          Do you mean th e Dumble forum at amp garage?
            Originally posted by rocket View Post
            Hi,
            Yep - do a search over there for 'D-lite reverb' or 'one tube reverb'
            The Amp Garage :: Search
              Image hosting, free photo sharing & video sharing at Photobucket
              Blues amp picture by tubenit - Photobucket
              56T reverb w/VVR picture by tubenit - Photobucket
              Plexi 25 w reverb w/ MTS picture by tubenit - Photobucket
              Here is an example of 5 different amp where I've used that. I like the way it sounds more than the Fender reverb. I have owned and played Fenders with reverb. This verbs more mids but it is not as intense as the Fender surf sound.
              The first 3 photobucket schematics are the amps I currently play/own.
              I use a dwell which I usually have set between 5-7 & the reverb pot is usually set between 3-3.5. It has all the reverb I need or want.
              It's not my idea, I stole it from the D'Lite guys.
              With respect, Tubenit
                thanks tubenit
                what transformer is used in there?
                  RT
                  I use a typical Fender replacement trannie and tank like in a Princeton Reverb or Deluxe Reverb.
                  Tubenit
                    thanks,
                    this is my first build so i may seem a bit dense
                    you mean 022921 or 125A20B
                      Yeah that the RT he means (and a type 4 Accutronics tank with an 8R input impedance I suspect). However since you would be running a 1/2 12AX7 into the RT (which has a 15k primary and an 8R secondary), you may want to try a tank with a different input impedance in order to get a better reflected load for the 1/2 12AX7 driver, or use Merlin's idea of a SRPP EEC88 to drive a mid-high input impedance tank directly (i.e.; without an RT)
