BF Princeton - aa964 / aa1164
    Bluemonk:
    It seems like a lot of people mod the non reverb princeton to a long tail PI to pick up some much needed gain in the circuit. Basically a single channel BF deluxe. You can use a 12AT7 or AX7 in the PI to change gain. Good luck on your build.
      Ok thanks for the infos, ill buy the 40/20/20/20 caps and the clamp, i'm now at the point for the other caps, i found mallory 150 series, looks cheap... some of you guys have tried it ?
        Spiky - are you in the U.S.? If so, your best bet is to buy from a supplier who specialized in tube amp components. You can always count on Hoffman Amps to have the right part(s) at a decent price. Antique Electriconic Supply has a bigger selection of components but not as focused on tube amps. Mojo Musical Supply has great cabs and carries some parts the others don't, but I'm not a fan of some of the booteek-style components they carry. Between those three you can find just about anything you need.
        Hoffman Amplifiers, Tube amplifier parts, tube amps, tubes
        Antique Electronic Supply
        Mojo Musical Supply Vintage Musical Supply Parts for Amplifiers & Guitars
        For film caps, 400 volt Mallory 150s are fine IMHO (630 volts work as well - they're just a bit bigger). Orange Drop 715 (polypropelene) caps are popular, especially for Fender builds. Xicon polypropelene caps are cheaper and smaller than Orange Drops. There are LOTs of opinions about capacitors and their effects on tone.
        One thing I learned the hard way is that sourcing parts from more than 2-3 suppliers starts driving your shipping costs way up.
        Hope this helps,
        Chip
          Hey ! Thanks a lot again for the quick answer ! I'm located near Montreal, Canada. I don't think there's tube supplier here hehe so i'm buying my stuff on the internet , angela electronics or bgmicro ... i found
          Watts Tube Audio ~ Tube Guitar Amp Parts
          to buy my caps, i have almost all my stuff to start building my amp, the only thing i need now are the tubes and something to to the decal on the front when i'll finish building the hardware
          casinolevant levant casino
