Any 8X El34 amps here?
  • Any 8X El34 amps here?
    I got this old Jamm amp in which has 8x EL34. I don't like the original schematic so I was looking at other schematics on 8x EL34 amps.
    Can't find any; any help?
    Can you show the original schem first ?
    And some phots of the guts would be nice ; must be a huge OT.
      I'll make the schematic digital soon! it is part SS (preamp) part tube (PI, buffer and output).....
      Thing is HUGE! Biggest transformers I've seen; the choke is bigger then most power transformers
        what are you trying to achieve by looking at a schematic for an amp with 8 el34's? its just like an amp with 2 but 4 sets of 2. (so double one with 4). its the same circuitry in parrallel. just takes a bigger transformer as you've noticed.
        sounds like an interesting amp though.
          I've worked with these kind of amps before and they all had buffers set between the PI and the powertubes (tube buffers); I just wanted to know if that was nessecary or what designs were used in this.........
          PICS!!!!!
            PICS!!!!!
            There is no reason why not having a tube buffer between the PI and the power tubes.
            ______________________________________
            Gary Moore
            Moore Amplifiication
            mooreamps@hotmail.com
              OK, so it'll behave just like a normal amp but then just with more tubes. Great!
              Schematics:
              PSU
              Poweramp; only drew 2x EL34
              Preamp
                Bernard,
                Could you post the preamp in a bigger resolution, the values are illegible.
                So it has a transistor preamp ! Where is the other half of the ecc83 before the PI ?
                  what a monster!
                  SS preamp and 100w brute watts output...kind of an inverse bedroom amp...
                  not quite what I am looking for but to each there own!
                    Bernard,
                    Preamp, now bigger
                    The other half of the ECC83 is not used.
                    The PI tube is an ECC85 tube. No heater on pin 9 on this tube. Why was this done? Is the ECC85 a nice PI tube?
                      The ecc85 for PI is a good tube it can deliver more current than a ecc83/ 12ax7 and pin 9 is a shield between the two triode halves.
                      I don't know what the function is of those diodes at the front of the preamp . Beats me, can't be clipping can it ?
                      Alf
                        I've seen this kind of clipping before as a method of compression.
                        I'll make a part of the schematic again; clearly I can spot some changes that were made after the PCB was made. Dunno by who
                          PICS!!!!!
                          ahh, makes sense. buffers tend to be used in more hifi designs (meaning amps where fidelity is desired). with more output tubes you would probably want a lower impedance feeding them, but when it causes a problem i dont know. a PI tube that can feed more current (ecc85 compared to a 12ax7) is a good start as they tend to have a lower output impedance in most cases.
                            Tnx! A simple cathode follower as used in older Fender studio models have my interest so I'll try em!
                            For the others, here's how the preamp's input was set up: Picture
                              To me it looks more like input protection for the FET.
                              Cheers,
                              Albert
                              PS: I have an old "LAY Power Block" lying around with 10 x EL34
                              Haven't opened it up yet. IIRC it has an ECC81 LTP inverter.
