Can anyone let me know what happened here?
This amp that I'm building is Cathode Biased 2x EL34 amp using a 125R 10W Cathode resistor (roughly 95mA of plate current per tube) with a supply voltage of 350VDC. Actual plate voltage from plate to cathode is 315VDC.
The center tap of the B+ winding is connected to a 200R 25W resistor (that adds the compression and sag of a 5U4 rectifier tube) and the high voltage leads of the B+ are connected to a Full Wave rectifier using 2x 1N5408 diodes.
A friend of mine was demoing the amp and he said that the amp's volume faded out after a few minutes of playing and eventually died. My first thought was that I had biased the tubes too hot which might have caused them to fail so I installed a 160R resistor in place of the 125R and tried it again. Well after playing the amp wide open the tubes died by making a bit of noise and then silence. I thought "Oh crap the tubes died!" and as soon I thought this I heard a loud POP and a huge puff of smoke only to notice that the 200R resistor had blown apart.
What would have caused the resistor to blow? Should the B+ fuse have blown to stop this? Did the dying tubes cause the extreme current that destroyed the resistor?
I'm really at a loss on this one. Is there anything that can be done to increase the reliability of this amp?
Thanks so much!
Thanks so much!
