Balancing a Parallel effects loop.
  • Balancing a Parallel effects loop.
    Hey all!
    I'm building a valve amp for my major project at uni and have just hit a bit of a stumbling block on some of the theory with a loop.
    I've read Blencowe's book (and website) and have quite a good understanding so far. However, I want a parallel loop in my amp and, can't seem to find the equation (or similar) to work out the values of the resistor before a wet/dry mixer (if you have the book p272 fig 11.20 the values of 10k and 100k are used) so that the signal is relatively balanced.
    Could anyone help me with this. I need to justify every single value of every single component in my amp to get good marks!!! Thanks for any help, it is greatly appreciated!
