Never mind. I had an older browser window and RG already answered the question.
There is PCB and then there is PCB
It's a mechanical issue. The thermal coefficient of expansion of copper and glass-epoxy are different. The longer a parallel run of copper and glass-epoxy, the more stress temperature changes put on the bond between the PCB stock and the copper trace. PCBs with unequal top and bottom side coverage tend to bend with large temperature changes, just like, and for the same reasons as, bimetallic thermometers and thermostats. Bending the trace ever so often lets the trace have some bending compliance that straight runs don't have. It doesn't have to be much. Just some.
Wider traces have less problem with the copper delaminating, as there is more surface area of adhesive to the PCB in a given length of run. Thicker copper makes the copper stronger and needs a wider trace to avoid overstressing the adhesive.
It's not an issue in hand wiring or ribbon cables.
A long, thin trace doesn't automatically fail, or even mostly fail. But if you have the space, a couple of wiggles will ensure that it almost never does.
Just one of those things you pick up over time.
Originally posted by GainFreak View PostThanks for this detailed answer. I guess this will apply mostly if we're talking traces for tubes' filaments?
Just a long trace presents the problem if the board can flex. On the amp boards I did, I star grounded the PCB; every circuit section had its own local ground domain, and that ground domain had its own ground trace back to a star ground at the negative of the first filter cap. The ground wires didn't carry significant current, but could have been prone to cracking or tearing loose from solder connections if nothing was done about flexure stress-strain. In some places there was room to wiggle the trace every couple of inches, and in some places not. The PCB was in a head with the tubes providing their own private oven, and measured air temps went up to 58C. I solved this one by putting two steel ribs down the long dimension of the PCB. No amount of heating would flex the PCB, so the trace copper didn't get a chance to crack with flexure.
Copper work hardens. Flex a PCB a little and over time the copper hardens and eventually will crack. Solder work hardens worse than copper. For reliable boards you have to figure out how to not flex that stuff.
When I was doing research for the amp, I interviewed some grizzled old amp techs and asked them to show me PCB amps they didn't like.
One guy pulled out a control board from a M*****ll. It was 3" wide and 19" long, had 20 PCB mounted controls/jacks on it which were soldered directly to the PCB, and when held in the middle and moved up and down, flexed like birds' wings flapping. It was almost an example of what not to do: thin PCB material to make flexing easy, controls hard-soldered to the PCB to transfer operator movements to stresses on soldered joints, large number of controls to remove before any repair action was possible, special parts needed for controls, long skinny PCB not supported mechanically.
Our amps were intentionally designed to be the opposite. Thick PCB, board-mounted stiffening ribs, thick copper, all controls on flying wires, access to all components without removing the PCB from the box, and the ability to replace pots and jacks with standard parts without even removing the chassis from the box.
It's very possible to design reliable and easy to service tube amps. If you want to.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by R.G. View PostIt's very possible to design reliable and easy to service tube amps. If you want to.
According to your earlier treatise on economics, we can deduce that the market actually wants the Bugera, Marshall Valvestate and Line6 crap, because that's what sells the most. All the corners that they cut in design, they have to cut to stay in business.
Of course, I don't really believe this and suspect you of sleeping with Milton Friedman."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by R.G. View PostIt's very possible to design reliable and easy to service tube amps. If you want to."Take two placebos, works twice as well." Enzo
First of all, I am not a big fan of PCB's for tube amps. Please don't give me the positive arguments for them. I've been building, repairing and modding guitar amps for over 30 years, and I have my own reasons for liking turret/terminal boards and PTP hard wiring.
One of the reasons a lot of PCB-based amps suck is that, often, the reason they exist in that domain was as a result of cost-cutting. The cost-cutting measures don't stop at PCB design, but goes all the way down to component level, and man, I've seen some of THE CHEAPEST shit components in amps nowadays, even flagship stuff from major manufacturers! They don't SKU, for instance, separate 100K plate resistors for the handwired amps. They use the same garbage all the way around, and THAT folks is what the problem is nowadays. As much as PCB's for tube amps aren't my thing, I won't blame the demise of "good" guitar amps on the PCB's alone, unless the boards are just of plain piss-poor design. It's the component quality that REALLY sucks. The REAL difference behind a manufacturer's reissue and a boutique copy lies mostly in component quality. Blame it on the bean-counters, not on the design engineers.
Unfortunately, this issue doesn't only affect guitar amps, but literally EVERYTHING we work on.
Originally posted by jrfrond View PostOne of the reasons a lot of PCB-based amps suck is that, often, the reason they exist in that domain was as a result of cost-cutting. The cost-cutting measures don't stop at PCB design"Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
What I'm using for controls is a separate narrow PCB, pots mounted and fixed to the front panel which excludes transferring stress on the solder joints, also this way you can easily remove the main board or the pots board if necessary.
On the Topic of PCBs.
Tube Depot make 2 tweed amp Kits that are more or less Point to point except for a PCB they use instead of a turret, or Eyelet board.
I'm mainly talking about their 5e3 Deluxe tweed kit.
My question is what will be the long term value of the amp with the PCB vs. a Amp made with a turret or Eyelet board?
On hand built stuff there's a lot of emphasis put on point to point.
Point to point is usually considered by many to be anything not on a PCB.
Here's a picture of the board in question.
Comments, and opinions welcome.
Thanks in advance.
Terry
Terry
for those interested in doing their own PCB work, keep in mind that it WILL sound different to a PTP wired design. blame that pesky stray L and C.
Originally posted by Gregg View PostWell I'm definitely not building PTP a 3 channel amp with tons of switching and MIDI just to compare it how it sounds to a PCB design. At least I don't know of such amps being built PTP.
nobody would say lead dress doesn't matter in an amp (well, nobody intelligent at least). this is the same concept, except there's no going back and changing it once it's printed.
edit: of course the reverse is also true: trying to copy a PCB design as PTP will result in a different sounding amp. how different? don't know till you try...
You know I'm not exactly a theory guy although you should know some basics so I think simple. If my design doesn't hum, squeal and/or produce any abnormal/unexpected sounds/noise it's OK for me. If it works for 5-10 years or more fault free even better. Can it be done better? Most probably yes.
Originally posted by kgnobody would say lead dress doesn't matter in an amp (well, nobody intelligent at least). this is the same concept, except there's no going back and changing it once it's printed.
Originally posted by big_teeePoint to point is usually considered by many to be anything not on a PCB.
Yeah. And everyone who had to solder even one wire inside the box says it's "hand wired".
Originally posted by GregSSo you can remove or replace parts without having to remove the board and turn it around?
Sorry - I could not figure out how to do this without removing the chassis from the amp, but it's only for PCB mounted Rs and Cs that this is needed. All the controls, switches, jacks, tube sockets, etc. are accessible and replaceable with the chassis in the box. Just drop off the back panel with the chassis still in the box. You don't even have to pull off the knobs except for the one you're replacing.
Originally posted by jrfrondBlame it on the bean-counters, not on the design engineers.
Originally posted by kg View Postfor those interested in doing their own PCB work, keep in mind that it WILL sound different to a PTP wired design. blame that pesky stray L and C.
For those interested in doing their own PTP work (or tagboard, or eyelet or turret board!), keep in mind that the position of every wire and component will be different on each "copy", so every single one will sound sound slightly different from each other, as well as different from a PCB version. Blame that pesky stray L and C.
Worse yet, what do you do when the owner complains that it doesn't sound the same, and all he did was move some wires around?
A PCB version *can* be made to fall within the range of variation of the handbuilt ones, and the PCB versions will vary much less from one another than the hand wired versions. For this we can blame the pesky consistency of the stray Ls and Cs on that PCB.
Not that you can't do a PCB layout wrong, or that it may be difficult to do correctly, but once you get it right, each one comes out nearly identically => if you do it right <=.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
