With the uni holidays approaching I'm looking to fiddle with a pseudo bass (*cough* 8 string guitar *cough*) pre-amp using direct coupling. I know I have two options (unless there are more ) in regards to level shifting, which is to effectively use a voltage divider or zener diode to shift the quiescent DC grid voltage.
I can get low current zener diodes (50uA) for 5 cents a piece, but I'm kind of wondering, how do I actually calculate the current flowing through the grid resistor, and hence, the zener. Is it simply just a case of the Rg + Ra resistor in series, or does something funky happen with the tube in the mix. If some weirdness does occur, how would the extremes of the signal through the valve affect the current through the zener.
Another odd question is what would happen if the quiescent voltage of the previous stage was something like 150v and I use a string of zeners to drop 160v. Would it be the same as having the grid voltage at 0 (like an ac coupled stage) and sticking a 10v diode (or equivalent resistor) at the cathode? I think this is referred to as grid bias, but I've never heard or seen it in a guitar amplifier.
I'm planning to stick with a stash of 12au7's I have so I can make the plate/grid resistors fairly small. The data sheet doesn't really state the impedance of the zener diodes but I can assume it's probably around 1k maximum at 50uA, so it shouldn't affect things too badly. The voltage drop at 50uA is... varied... to say the least but at 5 cents a pop I can afford to measure around a little.
