BigTeee's thread got me thinking about the cold clipping stage in the 2204. The same circuit is used as the 3rd stage in the "Iron Horse Collision" Express. A 12AX7 with unbypassed 10K cathode resistor and a 100K load resistor. Below is an X-Y plot of input vs output with a 33K grid stopper and a Y-T display under the same conditions. +/- 30V is the max my generator will put out. At no signal the plate is sitting at about 270V with a 300 volt supply, very near cutoff. The X-Y plot is very linear between cutoff and where grid current begins.
Somehow, I don't see any magic. Hard clipping mostly on one side of the waveform. Kind of mushy on the other side. I can do the same thing with an opamp and a few diodes.
