I designed and developed this ckt to be used in solid state and tube amps using only two transistors and a number of other parts, to be a cheap and easy to build and use ckt.
It will allow tube amp builders to use spring reverb units without having to use extra tubes or a matching/coupling transformer. It can be powered by using the 12volt dc filament voltage.
