I also posted this over at the Amp Garage, but wanted to ask the brilliant minds over here as well:
I noticed an annoying little buzz coming at the CF position of a 5F6A. The buzz would completely go away when the CF's driving stage was grounded.
The amp would still buzz with no guitar and the gain controls turned all the way off. The amp has a "humdinger" (or "hum balance") pot across the heaters, and I noticed that I could null out the buzz completely! But...
For any given setting on the gain controls, the humdinger had to have a different setting. WTF?!
Now, good thing for me, I had another amp that was almost the same without the buzz, and the only significant thing I could find between the two was the tubes - one had all JJ 12AX7s, and other had a Tung-Sol reissue, Mullard re-issue, and NOS RCA black plate.
Sure enough, I switched the tubes and buzz went completely away. And sure enough, the buzz came back in the other amp! After some more tube swapping I narrowed it down to just the CF position. Every single JJ would buzz, while any other tube would be quiet as a mouse.
Any ideas?
Any ideas?
