| | #1 |
| Member Join Date: Mar 2008
| 12AX7EH CF Failure
Hi, I don't know whether I hit a bad batch of these or something but recently I had 4 12AX7EH fail in CF position /driving tone stack/. One of them worked several hours, one worked for a month, couple of them failed shortly after turning the HV on. Anode voltages were 350-390V, Voltage drop at 100k cathode resistor before failure was 160-190V. Tubes were manufactured between 01.01.07 and 01.01.08. I read somewhere in a forum that other people were experiencing similar problems with 12AX7EH when used as CF. I have no problems when using them as regular triode gain stage. Actually they sound very good and have plenty of gain. I was wondering if anyone here had similar problems? |
| | #2 |
Look up the spec sheet on the tube and see what the max allowable heater to cathode voltage might be. I be suspicious you were exceeding it. Try elevating your heaters. |
| | #3 | |
| Quote:
I'm running regulated DC heaters feeding opamps and other stuff so the elevation of heaters is not an option here. | |
| | #4 |
| Senior Member Join Date: Jan 2008 Location: Galashiels, Scotland
Is the 12AX7EH of russian origin, cos if so they may be the same as 12AX7WB, which look to have the same structure as the 6N2P, but with different heater wiring. This could be important as although the 12AX7 has a max h-k of 180V, the 6N2P is only 100V. Hopefully someone will know if this is just supposition. |
| | #5 | |
| Quote:
A 12AX7 should have a certain amount of gain, and certain operating characteristics, but that doesn;t mean ALL criteria are the same tube to tube. | |
| | #6 | |
| Lifetime Member Join Date: May 2006
| Quote:
A guy walks into an amp tech's (doctor's) shop (office) and says, "Hey, tech (Doc) it burns this tube out (hurts) when I put this kind brand of tube in (do this.) The tech (doctor) looks up and says "Well, don't do that." | |
| | #7 |
| Senior Member Join Date: May 2006 Location: Cornelius, Oregon
The Sovtek 12AX7LPS is known to fail in the CF position, so it doesn't surprise me that the EH 12AX7 does it too. I'd use different tubes in that spot myself, especially after 4 of them fail for you. Save the EH for different locations in the amp and they'll work fine. Greg |
| | #8 | |
| Quote:
This problem with EH has been reported in other forums as well. In a russian forum for example somebody claims to have relatives working in the factory and they told him they're having technological issues. Also the comments there come from people using these tubes in hundreds so we're not talking about couple of accidents only. My tubes in question come from a group buy of 100 pcs 12AX7EH directly from New Sensor. I think if we have a 4% failure so far this looks like a problem to me . Now I'm using 12AX7EH in non-CF positions and they sound very well with plenty of gain. I'd hate to move to other brand/s but if this issue is not solved I'll have to. | |
| | #9 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
The CF position in guitar amps probably runs the heater/cathode insulation beyond any spec that any 12AX7 ever had. Even if it doesn't exceed the spec on DC conditions, it gets violated hugely on signal peaks. I'm more surprised by the fact that other tubes withstand it, than by the troubles with these particular tubes. Heater/cathode insulation was always a black art of the tube era. It's no easy matter to find a substance that keeps its electrical insulating properties year after year under orange heat and a high DC bias. Most glasses and ceramics that I know of start to conduct once they get red hot, and once this happens the DC drives ions through them and destroys them.
__________________ "Ohhhh miracle bulb shines feebly" |
| | #10 | |
| Quote:
| | #11 |
What I was trying to tell you is that the Sovtek 12AX7LPS and 12AX7LP does not work in that position in amps. Every vendor I know of tells you not to use those tubes in that position. Given that EH is made at the same factory, I would suggest that it is certainly feasible that it will have the same issue when used in that position. All of these tubes work great in other positions in the amp. So use the EH somewhere else and use some other brand in the CF position such as JJ as they work fine there. Problem solved. Greg |
| | #12 |
Yeah, I don't see the mystery either. This particular tube doesn't like being used as a CF, it is fine elsewhere. Most other tubes are OK with it. So don't use this brand 12AX7 as a CF, use one of the most other brands there.
| | #13 | |
| Quote:
Thanks to all for the feedback. | |
| | #14 |
New Sensor doesn't say anything on their site except advertising their products. You also have a hard time getting accurate info and specs on some of their products if you try to get it from them. The non-use of the EH 12AX7, Sovtek 12AX7LPS and Sovtek 12AX&LP as a CF has been all over the amp forums for at least 2 years. Now you know I guess... Greg |
| | #15 |
| Senior Member Join Date: Dec 2007
What's "CF" mean? Center-fold? Center-field? Crummy-Fender? What?
| | #16 |
| Senior Member Join Date: May 2006 Location: Milwaukee
CF=cathode follower.
| | #17 | |
| Quote:
Thanks for the heads up on this! Perhaps we can start a database here on problems and quirks of specific tubes... Steve Ahola | |
| | #18 |
I asked two European online shops about this issue. One of them confirmed about 12AX7EH adding to the list Tung-Sol, Sovtek LPS and LP. The other wasn't aware of the problem. Then I asked a major distributor and they also confirmed the 12AX7EH issue adding to the list any other spiral filament type tubes like 12AX7LPS, JJ ECC83s, Tung-Sol 12AX7, and Mullard 12AX7.
| | #19 |
| Junior Member Join Date: May 2007
This was posted over to the Metroamp forum. Sounds like it works fine anywhere but the cf stage http://forum.metroamp.com/viewtopic.php?f=13&t=20150 |
| | #20 | |
| Junior Member Join Date: Mar 2009
| Quote:
"Increasing voltage across the heater/cathode insulation increases leakage currents. Although Vh-k(max.) is specified on data sheets as being anywhere from 90V to 150V (except in some ruggedized and 'P' series TV valves), this is a very 'soft' limit, since it is usually given at an arbitrary leakage current, nevertheless, a suffieciently high voltage will [his emphasis, not mine] punch through the insulation to rupture the heater. Heater failure due to heather/cathode insulation breakdown is uncommon, but is most likely in cathode followers with high signal voltages or output stages with distributed loads (such as the McIntosh design)." "High signal voltages" sounds a lot like guitar / bass amps to me, where gain is god! Is speculation, no more, and I can't speak for the rest of those in the list. Perhaps raising the heater to the cathode level in CF might save a few tubes? Worth a shot, but probably not. It's my understanding that the EH is a Tung-Sol reissue. Again, could be wrong. | |
| | #21 | ||
| Quote:
Quote:
| | #22 | |
[quote=GainFreak;110284] Quote:
You know, if that works nicely I could probably just simplify the supply on my pre to do that for all the heaters... then just pop a relay like a turkey timer when they're hot and the resistance climbs Oh, well... maybe in a few days. | |
| | #23 | |
| Quote:
| | #24 |
| | #25 | |
| Junior Member Join Date: Oct 2006 Location: Nuernberg, Germany
| Quote:
But I've tried meanwhile Tung Sol reissues from 2009 production again in V2 of Marshall amps, after the vendor told me, that they've changed and upgraded the insulation issue of their preamp tubes - and... no more failure yet Yes, I like this tube very much soundwise and it's IMO the best alternative, if you don't go NOS. I've put this 2009 production tube in 6 or 7 Marshalls (w/o elevated heaters), amps of people, who're playing 30-50 gigs a year - and no claim until now! Hopefully no claim will be coming in future Larry
__________________ The fault almost always is sitting in front of the amp | |
| | #26 |
Nice. This didn't go out as a email notice to those with dealer accounts... they should be at least emailing about changes to their product lines. They don't, so I wonder how your vendor found out they changed insulation? Other than that, yay!! --GC |
| | #27 |
| I'll ask him tomorrow, today it's already too late here in Germany, business time is over. He's one of the biggest tube sellers here in Europe BTB Elektronik-Vertriebs GmbH - Preislisten and a few times every year he's in Russia, Saint Petersburg & Saratov. So I guess, that they've told it to him there in the factory? Larry
| | #28 |
That would definitely explain it!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Kalamazoo Model One failure... | harpidiot | Maintenance, Troubleshooting & Repair | 10 | 06-05-2008 06:14 PM |
| power supply failure? | EETStudent | Maintenance, Troubleshooting & Repair | 5 | 01-15-2008 08:16 PM |
| Cataclysmic failure! | axpro | Maintenance, Troubleshooting & Repair | 9 | 12-18-2007 07:56 PM |
| Experimental Failure? | voodoochild | Pickup Makers | 8 | 09-25-2007 07:44 PM |
| The failure modes of transformers | Glasgow | Guitar Amps | 5 | 09-17-2007 11:53 AM |
