Hello community,
I'm trying to built a low power version of a Jcm800 for my bachelors thesis.
As my university limits me to working with voltages below 40 volts I can't take the meassurements on the JCM800 myself. I would need them to verify the simulation of the JCM800 I did. While I found a lot of information on the DC Voltages on the internet, i didn't finde any on the AC Voltages for a given input Voltage. So if anybody captured the AC Voltages after the individual stages with an oszilloskope I would very much apreciate those pictures so I can compare them with my simulation. Obviously I would also need to know what input signal was used. I would prefer a sine signal on the input.
Right now my simulation only consists of the preamp stage, so those meassurements would do for now.
I will attach the schematics of my Simulation as well as the AC voltages I meassured.
This is the schematic my simulation is based on
This is my Simulation using a 800 mV RMS sine signal at 1Khz.
Preamp and Mastervolume are set to 100%
The Potentiometers of the Eq are all set to 50%, assuming that they are linear Potentiometers. I dont have this confirmed yet.
I assumed a high resistanz at the output.
As it is very easy to change the settings in the simulation, any meassurements you did would be welcome since I can adapt the Simulation easily.
This is the Simulation running:
The cable color matches the signal color on the scope
Settings are:
Green 20 Volts/Division
Yellow 50 Volts/Division
Orange 1K Volts/Division This seams very suspicious!!
Red 50 Volts/Division
Like I said, I don't have the possibility to hook up a scope myselfe and therefor I don't know what to expec. I really don't trust the Tubemodels I am using so I hope for some Input.
Best regards from Germany,
Florian
Settings are:
Florian
