Fender did this on the 6G series of Bassmans and never again as far as I know. The gain stage had a 220k plate resistor, 2.7k bypassed cathode and 100k cathode resistor on the follower. Any ideas as to why it was discontinued-the infamous grid current problem perhaps? Maybe just economics.
CF as First Stage
There are a lot of ways to make an amp. This circuit wasn't better or worse. They probably changed it for economy. It's a tube stage that's not amplifying anything. The ideology for doing it in the first place was probably to reduce the impedance for feeding the tone stack. In the early stages this seems to make more sense for bass than guitar since there would be less likelyhood of heavy bass notes swinging so wide as to clip the following stage. There wouldn't likely be any clipping at that point with a guitar, so none of the cathode follower mojo we associate with the later Bassman and Marshall amps. If you've heard one and liked it you could build one."Take two placebos, works twice as well." Enzo
I have a bass preamp that was essentialy the same a one half of a bassmans inputs, so i had an extra triode, and i just hooked it up as a cathode follower, it doesn't realy add or detract from the sound, it is a pretty clean bass preamp, i feel that it takes pedals quite well, fuzzes and such, although i don't think that has anything to do with the cathode follower dv coupled to the first stage.
In hind sight my anp is set up virtualy the same as the 6G bassmans, although i got the idea from the Traynor YBA300
Originally posted by clyde1 View PostFender did this on the 6G series of Bassmans and never again as far as I know. The gain stage had a 220k plate resistor, 2.7k bypassed cathode and 100k cathode resistor on the follower. Any ideas as to why it was discontinued-the infamous grid current problem perhaps? Maybe just economics.
Would like to see a schematic of the 6G if you have it cause I couldn't find it. Just the 6G6 which actually uses the Cathode follower on the second stage. I still think the follower on the very 1st stage does little except shunts some noise to ground which in a Bass amp is almost negligible but could benefit a high gain amp.KB
All 3 of the the 6G series Bassmans had a cathode follower as the first stage as described in the original post. Since there's none of that mojo, as Chuck calls it, to be had, I guess you do benefit from low impedance to the tone stack and tons of headroom. I just bread-boarded it and it sounds fine, nothing special and I'm not sure, like Leo, that it's worth wasting a triode over. A parallel stage would be more to my liking.
Originally posted by clyde1 View PostAll 3 of the the 6G series Bassmans had a cathode follower as the first stage as described in the original post. Since there's none of that mojo, as Chuck calls it, to be had, I guess you do benefit from low impedance to the tone stack and tons of headroom. I just bread-boarded it and it sounds fine, nothing special and I'm not sure, like Leo, that it's worth wasting a triode over. A parallel stage would be more to my liking.
Uhh... I can't actually find a schematic, but I'm fairly sure the first stage is just a gob standard gain stage directly coupled to a cathode follower. To legitimately have cathode follower as the first stage it would require some sort of blocking cap at the input side. But that's just me being pedantic Since it's a direct coupled cathode follower it really deserves special attention and the two stages can be rolled into one, as the behaviour of the circuit depends on both triodes. I suspect you wouldn't get the much sought after compression effect that the direct coupled cathode followers do really well at only the first stage. If there was a tone stack directly after, that would sort of make sense though. Also, reliability may have been an issue if the heaters weren't elevated, as it most likely violated the cathode-heater voltage limit.
The bass channel on all the above-mentioned. What do you see Bruce?
http://www.thevintagesound.com/ffg/s...g6-b_schem.gif
Originally posted by clyde1 View PostThe bass channel on all the above-mentioned. What do you see Bruce?
Originally posted by clyde1 View PostSorry, my bad. I was referring to the complete triode, as I usually do, as a cathode follower. I realize that it has 2 stages. Thanks for that. Would it even be possible to have a follower as a first stage?KB
Originally posted by clyde1 View PostWould it even be possible to have a follower as a first stage?
EDIT: Actually, on brief reflection, in Steve's particular setup, it will actually attenuate the signal. However, you can achieve what I was describing by implementing kind of the inverse of his stage -- with an anode resistor that is larger than the unbypassed cathode resistor
My design originally started out with the first stage as a cathode follower. It gave a voltage gain of 1 and just lowered the impedance to drive the Baxandall tone stack.
That worked great with active basses, but I soon found that I wanted some more gain. So I changed it from a cathode follower, to a classical gain stage with a very big cathode resistor. The gain is a little more than 1 when the "gain boost" pot is in its lowest setting, and increases from there. (At the lowest gain boost setting, Rp is 22k and Rk is 48.5||22 = about 16k)
I never thought about the input impedance at the time, however I can see now there is some bootstrapping action going on. I made the anode load resistor 22k as a compromise between achieving more gain, and a low output impedance.
The gain boost pot also introduces a high-pass filter effect with C7 as it is turned up."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
A follower as a first stage may be good or bad for other reasons, but it's decidedly not the best way to go for noise. The general rule for low noise is to focus on the first stage as a low noise design and getting the signal amplified up enough to get out of the noise floor. All of the noise of the first stage is amplified by all the following stages. When you're assigning the total needed gain to stages, put as much as possible in the first stage so that the following stages amplify its noise as little as possible.
There are other ways to get a low output impedance.
The input impedance of a normal triode stage is generally good enough for a magnetic guitar pickup, although there are ways to boost it too.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
