Got Merlin's preamp book (eventually!). Have been going skimming through it and trying to get to grips with the theory, but haven't had much time - so don't have a comprehensive understanding as of yet.
I have a question though: Say you have an example triode preamp stage (with all relevant voltages and resistor values given) and you want to replicate this stage as closely as possible (WRT gain, operating point etc) with a valve of similar characteristics, but not exactly the same as the original valve. How would one go about this? For example 12AX7 -> 6SL7. I know the 6SL7 has slightly lower gain and is more comparable with the 5751, but if I'm not mistaken you should be able to get similar output characteristics to a 12AX7.
I would assume that you would try to work with the same grid curve - as this will largely influence your overdrive characteristics. Then, I would think that you would look at a load line with a similar gradient, this is where my problem comes in: Would you position it on the plate characteristics plot using a similar plate current value, or a similar plate voltage value? Or have I got everything completely wrong?
Pre-thanks for any insight anyone can give!
