Hi all,
I have a Gilmore Jr kit amp from Guytronix/Gerhart, and I want to test out some different output tubes. The stock tube is 6N1P, and this can be substituted with a 12AU7, 12AT7 or ECC99 if the pinout for the heaters is changed.
As far as I can tell all of these tubes have an identical pinout, so I can't quite understand why the 6N1P seems to be the exception here. The 6N1P has heater wires going to #4 and #5, but not #9. I assume, but haven't verified, the 12A?7 would have wires going to #4/5 and #9. Can somebody explain this to me? I'm new to tube tinkering.
Also, the 6CG7 (noval replacement for 6SN7) seems like it would also work as a substitute. Does anyone know which heater pinout configuration this tube would require (i.e. same as 12AU7 or same as 6N1P).
Thanks in advance for any help here,
Tim
Tim
