I got this lovely empty cabinet for Christmas and want to build an amp with a 12AX7, EL84, 6X4 line-up. They should use about 1.7 amps.
I have a power transformer from a PA that used a 6K11, two EL84s and a 5y3. They used about 2.2 amps on the 6.3 volt secondary.
I plan to not use the 5 volt secondary at all. Will the fact the tubes use less than the PT can provide be a problem?
This is the first build I will be trying without using an all octal champ lay-out. I need to get a simple chassis cut and bent and then I am ready to try this.
