Opamp for effects loop? 0-18v?
  • Opamp for effects loop? 0-18v?
    I'm trying to build an effects loop for a Marshall sl5. The power supply is 18v or 12v and 0. Any ideas, is there something designed 0-18 that'll have a 0dc out? Thanks
    So you need to use a single-sided supply. That ain't no problem. You bias the opamp to DC offset equaling half of the supply voltage, then capacitively couple the stages.
    You can refer to SL5 schematic, particularly the reverb section, for examples.
    slot siteleri
