I've searched here and elsewhere, I haven't tried this because I'm worried about burning up expensive tubes, but if I have an OPT with dual primary taps (8K and 6k6) is there any reason I can't put four output tubes in (2x6v6 and 2x6bq5) wired up to the pair of winding taps and switch tube types with a DPDT on the filament supply to the output tubes?
It's a fixed bias amp of my own design with no NFB. I may put one pair of tubes on cathode bias to simplify switching and bias. I'm not sure if I need to switch the output of the PI or if I can parallel it, I'm sure there are other considerations???...Thanks in advance!!
Pete
Pete
