the forum seems to be having a latency problem with the page loads. it took a long time to commit my last post.
You should always check bias on the amp when you're servicing it. Always. It's just good practice and it's easy to do.
There are a few things that can cause problems with pair-pulling that most people don't think about. Although most people are familiar with the Z-matching problem, most people aren't aware of the voltage problems that can ensue with tube pulling.
Your PT is designed to provide a specific secondary voltage, and that secondary voltage will vary somewhat depending on the load being placed on the transformer. An amp's transformer is designed to provide relatively constant voltage supply with a design range of varying loads. The extent to which that voltage does not vary much within the range of specified loads is determined by the "regulation" specification of the transformer.
Going back to our 6L6 data sheet, the idle current for a pair of 6L6 at 450 VDC is about 122mA, and as I mentioned in the previous post the peak current is about 232mA. For a normal pair of 6L6 you might expect to see load vary by about 110mA between the idle and peak operating points.
Those numbers would be doubled for a quartet of tubes: about 2 x 122 = 244mA at idle and about 2 x 232 = 464 mA at peak. That's a range of 464 - 244 = 220mA.
From a practical standpoint the 2x6L6 PT should be designed to maintain a reasonably constant voltage when loaded with about 110 to 232mA of current, and a 4x6L6 PT should be optimized to deliver twice that. When you pull two tubes, you're asking a PT that's designed to be fairly constant in the range of about 244 - 464mA to work in the range of about 122-232mA. Chances are that your transformers regulation won't be as good at half of it's intended current, so voltages may rise. How much? Hard to say with hand-waving, but it could be significant.
That increased voltage could cause problems. Anything that ends up operating outside of it's proper operating voltage range could experience a shorter lifespan. If you go pulling tubes, you should expect that the B+ voltage would rise, and the bias voltage should change along with it. IMO re-biasing is important if you pull a pair of tubes.
Other things to look at would be the heater voltages. If your heater voltages were to rise by say 10%, that could put them outside of their normal tolerance range and shorten the lifespan on all of your tubes.
There are a lot of things to consider, but most people turn a blind eye to them. If you really wanted to be optimal about pulling a pair of tubes, you might want to consider replacing them with a dummy load so that your PT remains functioning in it's intended load range. I'm probably the only guy who bothers to do this.
Originally posted by trip
View Post
