"Sorry but it doesn´t work that way."
But the rectifier tube is before the filter caps. Chances are your bias voltage will be there first even if you used 1000uf. Whether the rule of thumb is correct is moot. Anyway, best to be true to the original schematic if you want the JTM45 sound. If you have a 8uf or 100uf on your bias supply, you aren't going to hear any difference. Only thing with the JTM45 is the voltage on the presence pot, but there is a update/mod for that and sometimes they squeal with the presence and treble all the way up.
