Originally posted by SoulFetish
View Post
I suggest you roll off the bottom end below 100Hz or so pretty quickly to attenuate hum. Making the cathode bypass cap 2.2uF will help a little. Add a 3.3nf cap in series to the grid and a grid leak of 470k roll to off below 100Hz.
You may want to tame the HF output from the tank with a resistor in parallel with the output coil above 2KHz or so with a 5.1k resistor.
Honestly it's very much a guess as I really don't have a good handle on the frequency response of the tank. I think it would be tough to measure. All to your own taste, naturally in any case.
I think you'll see about 30dB of gain on that stage.
PS: I forgot to mention that a cap in parallel with output coil will give you a resonance that you may or may not want.
