Gross! I once tried to destroy a small radio speaker by hooking it up to a 150w solid-state amp and playing bass through it. The cone tore into shreds, but the spider and voice coil kept on flapping...
I'm not sure about the 12% thing. I've measured both my homebuilt amps with one step mismatch in various directions.
The 50 watt "Ninja Toaster" (originally a trash-picked Sansui Q-55) only has a 16 ohm output. With 6L6s or EL34s, it used to give 50 watts into 16 ohms and about 25 into 8 ohms. This power drop was accompanied by red plates. With 6550s fitted, it gave 65W into either 16 or 8 ohms. This is good as it saves me buying another O.T. I'm convinced that the Sansui O.T. has ninja powers.
The 40 watt "Ninja Deluxe" (made from the guts of a late model Treble'N'Bass 50) gave 20W when fitted with 6V6s and mismatched one step upwards. (16 ohm load on the 8 ohm tap.) With 16 ohms on the 16 ohm tap, it gave 13W.
None of these is a 12% difference...
