New Month We are at $45 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
What characteristics do you get from parallel tridoes?
So the main benefit is noise reduction? Maybe a lower output impedance...for driving a tone stack, too? Forthat you'd probably be better off with a single gain stage and a cathode follower though I bet.
I would agree, a better solution to drive a tone stack would be a single gain stage boot-strapped to a cathode follower. I believe the main benefit of running parallel triodes is to fatten up the tone. I did this on my first 5 watt prototype amp. However, on my next 18 watt prototype, I'll run a triode in parallel with a pentode front-end. Maybe I'm giving away too much on how I am intending how to bring back the pentode front-end on a guitar amp.
-g
Gary Moore
Moore Amplifiication mooreamps@hotmail.com
Yeap I thought parallel triodes fattened up the tone too. In fact I heard this for myself for the first time the year before last when I observed a local musician plug a short lead from the lo gain input of one channel to the hi gain input of the other channel of his 5E3 - which is one of the things that inspired me to build a 5G9. I can't wait to finish it and take it for a test drive. :-)
Hmmm, a fatter tone is something that sounds interesting to me.
Being the tone grasshopper around here, could someone explain to me what is
meant by "fatter tone". It sounds appealing. More <width, depth, crunch,?>
Actually, crunch could use a definition as well.
Technically, does it mean that a sine wave would be squared up a little bit,
like in fattening up the sine wave ? Seeing as this is only one stage, does
this fattening apply only to half of the wave ?
-g
You're late, some of us are already building pentode preamps.
I've disected a couple of old burned out pre-amp pentode tubes, put them under a microscope, and I believe I have determined the failure mechanism. I'll find out later on if my fix abates this problem.
-g
Gary Moore
So, to actually wire up parallel triodes, is it simply jumpering 1-6, 2-7, and 3-8? Do you treat is as one triode when figuring the plate and cathode resistors? I suppose it doesn't make any difference which pin of each pair you use to make connetions to?
Paul P
I'd define it as more lower midrange. A scooped tone isn't fat. A tweedy tone (defined as sounding like a Tweed Fender) is fat. Lots of that nice lower midrange. But that's just me.
Thanks. This makes sense, and something I can sort of imagine. I searched
for a tone glossary on the net but found nothing, surprisingly. There are a
lot of terms floating around like grind, grit, punch, crunch, squish, sponge,
dynamic, dirt, bees in a can, icepick in the head, etc, etc...
That would be one way to do it. My circuits are little more complex.
-g
Gary Moore
