Originally posted by K Teacher
View Post
- I thought you were going to use a PM speaker, so why worry about the field coil speaker and its energizing current?
- It is true that the efficiency of a field coil speaker increases with the field current. The generation of the magnetic field doesn't require power though, rather there are power losses caused by the DCR of the coil wire. All this power gets dissipated as heat. I assume there is an optimum field current for the speaker.
- There is no reason why a 6L6 would increase the B+ or need higher B+. Typical plate current in SE class A is around 50mA.
- Nothing wrong with using 2x6V6 in parallel if the PT can supply enough current.
