Against “mechanical connection”
    ...and carrying high voltage doesn't matter regarding reliability of solder joints (very high currents >> 10A would be a different story).
    Solder joints of PTP wired and chassis mounted power tube sockets hardly ever fail. Quite the contrary to board mounted sockets
      Thomas organs used just wire wrap no solder.
      nosaj
        nosaj
        I was trying not to mention... but since you have done so, add Soundcraftsmen gear. Remember those graphic EQ's popular in the 1970's? Them. They made power amps too, all done up with wire wrap connections. Maybe other hi fi components too. Talk about planned obsolescence, oy! When attempting to repair, I never knew whether I was looking at some wrapped connection that had corroded into oblivion, a stiff solid-core wire that had cracked, or something else that had gone kaput. Let's put it this way, on those rare occasions someone offers their Soundcraftsmen gear to fix, I politely but firmly decline. Recently I had a go at an AIWA stereo receiver from about 1990, cram jammed with wire wrap. Same thing, it wound up in the trash can.
        I'll bet wire-wrap Thomas organs are just a breeze to fix, right?
        If I'm not mistaken the wire wrap technique was developed for computer construction, late 60's or so. Super thin kynar-insulated wires, 30 gauge IIRC. I s'pose it was good for the time. The wire wrap technique was touted to be perfectly reliable and much faster (cheaper) to construct compared to soldered connections. But those old computers are way long obsolete aren't they. I'm sure that's best for one and all.
          Its a well know fact I'm an organ harvester I just don't sell on the black market. Organs give me plenty of parts to tinker with and a look into the past of how things were done.
          nosaj
            Wire wrap required tension and sharp edged terminal pins.
              I have seen TV seets wired with wire wrap.
