MEF members....
I have a dozen or so XLR cables, all wired up, no noise, life is good.
I just came a cross a brand new cable, a brand X, where the case of the XLR is wired to pin 1 - ground.
I believe the consensus on XLRs is that you do NOT connect the case of the connector to the ground pin. I have a handful of new cables where that is the case. But this one in particular does have that connection. Is there a scenario or application where it is helpful (desired, recommended, etc etc etc) where you DO want the case grounded?
Thanks in advance.
Thanks in advance.
