I don't so much have a particular question but i'd just like opinions on large vs small chokes and even more so, choke vs resistor and what you think the difference is in feel and tone. My final cap, a 50/50uf is due tomorrow. Already replaced the other 'lectros and when i replace the old can tomorrow i'd like to have a little better idea of what you all think about the feel and tone of big vs small chokes and choke vs resistor. I tried a 230R 15w in place of my 20H in my 6V6 marshal preamp style build and i think i prefer the resistor. Seems like the choke is really stiff feeling by comparison and i'm not so sure i get better dynamics with it. Seems the resistor sags more when i hit it hard so it actually seems more dynamic. I know 20H is huge tho and i wonder if say a 3H might give me that less stiff feel but with other advantages' Not sure what i wanna do but i know u all will get me thinking about it in ways i am not now. Heres the schematic again so u don't have to go look at the other thread if u want to see what i'm dealing with.
choke size and choke vs resistor
The resistance of the choke in question may be significant. Early Marshall RS type 20H chokes are typically around 500ohmsMy band:- http://www.youtube.com/user/RedwingBand
One thing I've always suspected regarding chokes vs. resistors for the screen supply is that the choke can sort of act as an inductive signal load for the screens and minimize higher frequency voltage spikes and overdissipation. I'm not scholarly enough to back this up but it seems intuitive. I started to consider this after building an amp modeled after one that would typically use a choke, but I instead used a resistor and had some trouble keeping the screens from overdissipating under heavy clipping conditions."Take two placebos, works twice as well." Enzo
Originally posted by Mick Bailey View PostInterestingly, the aforementioned Laney doesn't have screen resistors. You wouldn't expect that, but it works just fine."Take two placebos, works twice as well." Enzo
... may provide better spike protection.
Do you mean screen voltage peaks?
I can't think of an effect that would increase the voltage at the screens in a typical amp.
At high output/clipping screen current strongly increases making screen voltage drop (slowly without screen resistors added by an immediate drop with screen resistors).
Additionally screen voltage drops by B+ sag at high output.Last edited by Helmholtz; 09-23-2022, 10:50 PM.- Own Opinions Only -
Originally posted by pdf64 View PostThe resistance of the choke in question may be significant. Early Marshall RS type 20H chokes are typically around 500ohms
- Likes 1
Originally posted by Chuck H View PostOne thing I've always suspected regarding chokes vs. resistors for the screen supply is that the choke can sort of act as an inductive signal load for the screens and minimize higher frequency voltage spikes and overdissipation. I'm not scholarly enough to back this up but it seems intuitive. I started to consider this after building an amp modeled after one that would typically use a choke, but I instead used a resistor and had some trouble keeping the screens from overdissipating under heavy clipping conditions.
When do you see "screen spikes" and how do they look?
At high output/clipping screen current strongly increases making screen voltage drop.
EDIT: More research is warranted but I still don't have a bench in my new digs after a year here. Plus I'd have to get my old Marshall back in shape as it's currently in a sort of half done project stage."Take two placebos, works twice as well." Enzo
High voltage spikes at the plates are caused by the (partly) inductive load when plate current abruptly changes as with clipping.
A sudden drop of current causes a flyback spike.
Screen are either terminated with screen resistors or directly connected to a filter cap whose low impedance doesn't allow for spikes to develop.- Own Opinions Only -
- Likes 2
Originally posted by Helmholtz View PostHigh voltage spikes at the plates are caused by the (partly) inductive load when plate current abruptly changes as with clipping.
Screen are either terminated with screen resistors or directly connected to a filter cap whose low impedance doesn't allow for spikes to develop."Take two placebos, works twice as well." Enzo
- Likes 2
There is no too much reason for sag,or substantial one,as time the current draw after plate supply is pretty consistent. You may try a simply sense diode after the plates supply cap, between plate cap and screens cap nodes if you screens current is limited .Last edited by catalin gramada; 09-24-2022, 02:03 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
