Yes, that's a variation of uneumann's circuit using the same principle of separating the 2 NFB paths.
Regarding the amount of speaker signal injected to the tail, the bootstrapping effect should work best if the signal at the lower end of the 56k tail resistor is almost the same as the signal at the cathodes. With almost same signal at its ends the 56k looks like a very high tail impedance as seen from the cathodes and thus improves balance.
Make sure your voltage divider resistors have sufficient power rating with speaker voltages above 20V.
I.e. the 560R should be a 2W type.
