Well, i have come to realize i must be different than everyone else with respect to opinions about small amps in a band setting. I don't like cranked amps ! Maybe non master amps w/o high gain preamps, but those are not even a considerations for me as i don't like relying on the room to allow loud or having to rely on pedals. I actually prefer cascaded preamps types with the master under 1/2, something that was easy with my 50 watt marshalls i used to gig with for many years. Those never got past 4 on the master. And we aren't a killing loud band either. As most here know by my never ending posts, i've been configuring a 18 watt 6V6 amp with a 3 stage preamp and it just sounds fabulous till it gets really loud at which point it becomes a wild animal. Even with the gain down it's like the output is adding too much drive at band levels. Yes, been considering a high sensitivity speaker but so far haven't found the right deal on the right speaker.
Today i'm heading out for another play with the band and the amp sounds very different than it did last time with the changes i made. But i have little doubt i will have the same issue. I just don't understand the whole small amp thing at all except and unless no one uses them with a cascaded preamp. I suppose thats the only reason i seem to be the only person on earth that dislikes it. If it sounds as great as it now does but the volume thing is still an issue i think i will pass on the louder speaker and go for a new PT and possibly OT if i can't make my 6.6k OT become efficient (use different tap than the speaker ohms?) for EL34s or 6L6. And if i do that i will either replace the board and components (it's a hideous slop fest) or may well just build an entire mew amp. I think it could be a great amp as it is if i could get 30-50 watts from it. But for me a cascaded preamp is essential and in a 18 watt amp that's just not a good combo imo. In fact i don't think i would want to use any amp again in that range of power other then as a home amp. I need control and more watts gives me that all the way till it's much louder then i would ever use. With a good preamp thats the ideal as far as i'm concerned. Small amps are indeed as has traditionally be said, practice amps. Just thought i'd post my opinion. But who knows, after tonite maybe i will be eating my words but if i had to wager i'd say i won't. (one bet i'd LIKE to lose
