Hello. Complete newbie regard CCS. Found this schematic on internet .May someone explain how it works (for ignorants) ? and how can be adjusted in respect with negative supply voltage and constant current please ? I.m tempted to adapt this to a -100v negative source to assure 2 mA constant current to 12ax7 cathodes. Thanks.
CCS explained
CCS explained
Last edited by catalin gramada; 01-15-2023, 06:42 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
The R8,R10 potential divider sets 23V across R10, subtracting 1V for the Vbe of Q1 puts 22V across R12 (2k2) which defines a current of 10mA for Q1 emitter and collector (ignoring the small base current). 10mA is 5mA for each half of V1. 5ma across R9 is a voltage drop of 5 x 39 = 195V. B+ is 335V, 335V - 195V gives a plate voltage of 140VLast edited by Dave H; 01-15-2023, 07:17 PM.
- Likes 3
Originally posted by Dave H View PostThe R8,R10 potential divider sets 23V across R10, subtracting 1V for the Vbe of Q1 puts 22V across R12 (2k2) which defines a current of 10mA for Q1 emitter and collector (ignoring the small base current)Last edited by catalin gramada; 01-15-2023, 07:27 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
So, with same -45v supply, for instance if choose R10- 1.5k R8-15k and set same current by R12- 4k I will get same result, the ccs it will work as same please ? Why -23v into the base was set and not -10v or -40v please ?Last edited by catalin gramada; 01-15-2023, 08:24 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View Post“If you have integrity, nothing else matters. If you don't have integrity, nothing else matters.”
-Alan K. Simpson, U.S. Senator, Wyoming, 1979-97
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
https://sites.google.com/site/stringsandfrets/
- Likes 1
The schematic in post #8 doesn't look like it would work to me. I suspect a mistake in the drawing.
Here is a slightly different current source that uses two transistors from a Fender Super Sonic.
- Likes 1
CCS means "constant current source".
The term is used for a circuit that provides a very large AC impedance while dropping only moderate DCV.
In our example here it is used to improve the balance/symmetry of the differential amp (long tailed pair phase inverter).- Own Opinions Only -
- Likes 1
Originally posted by catalin gramada View PostQ1 base current meant the current settled by R 12 right ? Well, large meant at what order at magnitude minimal , optimal ? 10x maybe ...?
- Likes 2
Wost case assumption would be the transistor having the minimum Hfe of 30, resulting in a current ratio of 9.
https://www.onsemi.com/pdf/datasheet/mje340-d.pdf- Own Opinions Only -
Originally posted by catalin gramada View PostSo, with same -45v supply, for instance if choose R10- 1.5k R8-15k and set same current by R12- 4k I will get same result, the ccs it will work as same please ? Why -23v into the base was set and not -10v or -40v please ?
