Hey Dave. I just replaced R12 in the circuit to 12K to ensure 2mA current in my 12ax7 cathodes and it works. The rest of the circuit is identical. -50V well filtered, not regulated was used. I saw in other thread you taking about thermal stability. What about it ? Should I replace R10/C3 with a 24V zenner diode to ensure consistent voltage in to the base please ? Thanks.
CCS explained
Last edited by catalin gramada; 01-31-2023, 07:03 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostHey Dave. I just replaced R12 in the circuit to 12K to ensure 2mA current in my 12ax7 cathodes and it works. The rest of the circuit is identical. -50V well filtered, not regulated was used. I saw in other thread you taking about thermal stability. What about it ? Should I replace R10/C3 with a 24V zenner diode to ensure consistent voltage in to the base please ? Thanks.
Originally posted by Dave H View Post
Sorry, I don't remember talking about thermal stability but I'm sure it will be fine as it is without the zener.
Last edited by catalin gramada; 01-31-2023, 09:24 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
