Also, line voltage can vary quite substantially.
Tweed Vibrolux 5E11 vs 5F11 Fuse Rating
Originally posted by The Dude View PostAlso, line voltage can vary quite substantially."Take two placebos, works twice as well." Enzo
- Likes 2
Originally posted by Chuck H View Post...in San Jose, Ca. where I lived sixteen years ago the wall voltage would vary between 117 and 129 all the time...
Note that the meter calculates the average as the weighted value of all 1,993,497 samples taken. That's why it differs from a simple calculation done with the min and max numbers.
- Likes 1
Originally posted by x-pro View Post"drying your oars""Take two placebos, works twice as well." Enzo
- Likes 1
Originally posted by Tom Phillips View PostThat's pretty extreme."Take two placebos, works twice as well." Enzo
Of course, line voltage can vary from time to time in the same location. But, what I was mostly referring to was line voltage varying from place to place or venue to venue. We have Furman line conditioners with mains voltage readout on much of our gear. I've seen line voltage over 125V in some venues and as low as 110 in others. I imagine even more radical swings are possible depending on load variance."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The assertion that all voltages can vary ± 20% troubles me. This can be true for preamp tube's plate and cathode voltages, because the resistors connected to these pins had usually tolerance of ± 20%, thus causing that much voltage variation.
OTH, if you apply the same variation range to the B+ of 305VDC, means the amp is supposed to operate from 366 to 244VDC… I don't buy it, it's too extreme…
For this to happen, the PT secondary winding needs to vary ± 20% or the outlet voltage needs to vary that much also… It doesn't seem plausible to me…
Using The Dude's example, 125 to 110 would be approx. ± 7% voltage variation from mid-point...
- Likes 1
It's printed right on the Fender schematics for a reason. It means voltages can vary up to that much. I don't think it would be practical for them to figure out the tolerance for every possible voltage, so they give a worst case scenario.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 3
Originally posted by g1 View PostIt's printed right on the Fender schematics for a reason. It means voltages can vary up to that much. I don't think it would be practical for them to figure out the tolerance for every possible voltage, so they give a worst case scenario.
- Likes 2
Originally posted by K Teacher View PostThe assertion that all voltages can vary ± 20% troubles me. This can be true for preamp tube's plate and cathode voltages, because the resistors connected to these pins had usually tolerance of ± 20%, thus causing that much voltage variation. ...;
So yes, my thinking is that degree of acceptable variance can only really apply to downstream voltages, where normal valve variance means current draws through dropper and load resistances will affect resulting voltages.
Also it allows a fair degree of wiggle room if transformer specs are changed, for whatever reason, avoiding a need to amend the schematic.
Originally posted by pdf64 View Post... avoiding a need to amend the schematic.
- Likes 2
