Okay, now I have new caps in my amp, but the volume is really low, and distorted. I had never done a cap job before, so after changing the 7 smaller ones inside the chassis, I hooked up the speaker, and made sure the amp still worked. Then I changed the first 2 in the filter can (the ones without resistors) and made sure amp still worked. Then I changed the other 5 and the associated resistors, and the 470 resistors on the power tube sockets. When I plugged the amp in again, I neglected to check the power and standby switches. THEY WERE BOTH ON. Now It seems to be running on just one power tube. I can remove the one closest to the preamp tubes and get no change in sound. Pins 3,4& 6 all measure over 500v on my $2.00 meter, which is higher than speced on the schematic.
Any advice? Did I ruin the OT? What do I do now?
