Fender Hot Rod Deluxe question
  • Fender Hot Rod Deluxe question
    This thing is killing me! It had a loose solder joint on the 2 5w 470 ohm resistors and I replaced a volume and a treble pot. Ok, it powers up fine but slowly dies to this really low volume distorted volume.
    -all tubes are good
    -plate is 400v, the thing is perfectly biased at 70% on each side, no fluctuation
    -the 5w resistors get really hot and i just ordered some more
    -the speaker and connections are fine.
    -im going to look for any open resistors today-any ideas? im looking around the 5w resistor circuit
    -the OT is 85 ohms and 100 ohms, which is a little odd to be out of balance, but thats where i checked the bias (as well as on the tubes)
    Any ideas, nothing else seems to be loose w the chopstick etc. Help!
    oh the 5w resistors are -16/16 on one side and -45/45 on the other.
      Not that it really matters much, but when in blue blazes did a Fender Hot Rod Deluxe become a vintage amp?\\You might have better results posting here:
      Maintenance, Troubleshooting & Repair
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
        sorry my other posts are for older blackfaces and i didnt look at the section
