I'd like to build a clone of the Magnatone 213 and am looking for some transformer specs. Plate voltage? Output transformer primary impedance? If I can't dig up the info I'll probably go with 340 volts on the plates and an 8K primary for the OT, like it was a 5E3 Tweed Deluxe. Did Magnatone do anything different than Leo?
Magnatone 213 or Titano 314 Transformer Specs
Originally posted by Diablo View PostI'd like to build a clone of the Magnatone 213 and am looking for some transformer specs. Plate voltage? Output transformer primary impedance? If I can't dig up the info I'll probably go with 340 volts on the plates and an 8K primary for the OT, like it was a 5E3 Tweed Deluxe. Did Magnatone do anything different than Leo?[url=http://moviesonlinefree.biz/]watch movies online[/url]
You wouldn't go too wrong with 8K PP OT, or higher. I don't have a measurement on the original OT. The valve diode and bias you choose will influence the main HT level. My clone has 300V sec and GZ32 for 360V at idle, but I idle fairly cool at about 24mA, rather than up at 30mA. The 10k PP works well, and the vibrato is excellent. I chose to choke filter and zener regulate the screen supply at 260V, which is not normal or required.
