Eden wt 400 issues
    When you "check" those zener diodes, did you just subject them to the diode test on your voltmeter? The only real test of a zener is to run current through it and see if it "zenes" at the 12v. it may act like a diode just fine at the voltage your meter uses. That doesnlt mean it works as a zener.
      I simply love that technical term.
      "zenes".
        Ah well, my degree is in communication, sometimes I try to make it work for me.
          wt 400
          Hi guys thanks for all the help,I'll check those vlaues and get back to you with the readings
            Eden WT400
            Hi Guys,
            Think I've found the problem,its the 12v zener (D13),it shorted,but I cant recognise the value on the part,it looks like 1n4742 or 1n4142,any help? once i replace it hopefully tonight I'll give my results,thank you again
              1N4742 is a 12V 1 watt zener diode.
              1N4142 is a schottky diode.
                1N4742 12V zener
                  Eden WT400
                  Hi there,
                  I've replaced the tip32,the two zeners the 12v and 15v,replaced the caps c9 47uf and c36 1000uf,and also the 1n4003 diode,last check i did was on the tube socket.here are the readings. on the tube socket.if this might be of any assistance,still getting 11.1v on the heater,is that enough?
                  Voltages from
                  4 to 9 = 5.5v
                  5 to 9 = 5.6v
                  1 to 3 = 59.4v
                  6 to 8 = 59.5v
                  2 to GND = -3.4v
                  7 to GND = -3.4v
                    Excellent.
                    11.1V will work but is a bit low; I always found a "12V" Zener there a bit low, specially since you lose at least 700 mV through the TIP base.
                    Use it as-is, but whenever possible replace that Zener with the next higher up ¿¿1n4743???.
                    My bread and butter Zener is 1N4744 which is 15V, so I guess the intermediate one *should* be what I suggested, anyway Google it.
                    Congratulations, don't forget to post your results.
                      Wt 400
                      Hi there thank you for your response,one more question,where would I put my dmm meter leads to set the bias voltage on this diagram
                        As stated on the schematic, DMM scale 200mV DC , Black to (B) point which is where the 2SA1494 emitter joins a .5 ohm power resistor; Red to (A) point, where the 2SC3858 touches a .5 ohm power resistor.
                        You are measuring the voltage drop across two power resistors that are in series.
                        • #27
                          WT 400 PSU Board
                          Hi There,
                          the pSu board on my wt400 has four 4700uf 80v caps,would I benefit by replacing them with 10000uf 80v,by giving me some extra headroom/output?
                          • #28
                            It may pay, *only* if the new ones are the same size (or almost so) , meaning they drop in, no major surgery.
                            The difference will be audible (a better PSU never hurts) but not that much.
                            More power? A little, not noticeable.
                            Most notable will be cleaner bass. You might even *think* there's less of it, because of reduced ripple.
                            • #29
                              wt400
                              Is there any mod I can do to get just a little more headroom/ouput?
                              • #30
                                Use bigger, meaner, louder speakers. What are you using now?
