DTT2500 AMP Problem - Speaker Poping and Crackling Noise
  • DTT2500 AMP Problem - Speaker Poping and Crackling Noise
    Hi Guys, Well I am new. I actually have a Cambridge Sound Works DTT2500, Had it for a long time and worked great, a little while ago I did a small repair on its power supply brick(had a bad cap on it that caused the SUb not to work so it needed replacing) since then I also noticed that it has had a white noise coming from all speakers, recently after running the speakers for a few hours at normal sound levels or playing rock and roll for 10 mins at high (80%) levels (just to test ) the thing starts making crackling and poping sounds from all speakers. This gets annoying when I watch movies on the PC.
    I have since replaced the power supply brick with a laptop brick, running great but the crackling noise comes back after a while. I really want to get rid of this issue. I opened up the amp but found no bad caps in it. Not sure what it could be. All connections are tight, the speakers and everything seem fine, so I think the problem is in the amp. Any one here with good experience with amps that can help me please ?
    Oh, and I should add, the amp has digital mute and environment switch, muting it from the amp makes the poping go away.
    Here is the setup. pretty good for me, but I just need to fix the crackling and poping noise
      I'm not the expert that some on here are...not even close , but it sounds like caps to me. If it is an old unit caps can dry out. They don't have to look bad to be bad. Good luck with it.
        Or maybe crappy ass soldering by the factory
          Or what Jazz said...see that all too often
            I have re soldiered most of the joints and they looked good to be honest. Do you think I should recap the whole thing? I bet thast gonna cost me a pretty penny. I was hoping there might be a spesific part I can repair. Do you guys have any experts on the amps in the forums that could maybe help me out? I can post pictures etc.
            Thanks Guys
              Did all this start AFTER you changed the PS ? A schematic would be nice too.
                DTT2500 amp fix
                PM sent.
