Replacing capacitors with different value is bad?
  • Replacing capacitors with different value is bad?
    Hello. I have an Alesis RA150 amplifier, recently i had problems with the relay and I made a lot of resarch and find out that many people with RA 150, 300 and 500 models have the same problem, and some of the comments I read recommend to replace the stock relay and the stock caps as well, so I ordered from Mouser.com a new relay and a new pair of caps but when the parts arrived I noticed I made a mistake and the caps are different value than the stock ones.
    The stock caps are 6800 uf 50v and the ones I ordered are 10,000uf 63v and obviously the new ones look like more quality but I want to know what could happen if I replace the stock caps with this new ones?
    Can this harm my amp in any way?
    Can it affect the sound for goof or for bad?
    Do you recommend leaving the old caps (they work just fine) or replacing them?
    By the way, I already replaced the relay and the cutting out problem is solved...
    Thank you,
    Leo
    Keep in mind the value of the 10,000 uf caps is 50% larger than the 6800uf caps.
    That in itself has repercussions.
    The caps will pull more current at startup, to say the least.
    Not knowing any of the parameters of the power transformer or the power supply itself, I would have to say that you are gambling.
    Will the 10,000uf caps work.
    Probably.
    Is the difference a big deal?
    Probably not.
    See what the issues are?
    It is a gamble.
    The correct answer would have to come from an Alesis engineer.
    Try contacting them.
    Or purchase the correct caps.
      Or don't bother replacing the caps if the amp is working OK.
      A lot of people in a lot of forums just automatically suggest changing all the caps on anything anyone has a problem with.
