Funny DIY power supply to board.
  • Funny DIY power supply to board.
    Well.......I guess that is one way of powering the preamp board. I removed the back panel to a Peavey amp and this is what I saw. ;-)
    Is that a circuit breaker? Geez that’s looking pretty dangerous to me too. I am not sure why they mounted it on there like that. Crazy.
      It is a wall wart power supply bolted to the back panel.
        What "preamp board" is this powering? The pedal board? An auxiliary preamp going INTO the Peavey amp? Surely it's not powering any board IN the Peavey amp.?. The description (as well as the photo) is ambiguous and confusing.
          The amp I am working on is a Peavey PA-400. The output transistors were removed and plug was cut off.
ID:	978107 Click image for larger version
          As you know, Peavey amps of that era have a preamp/control board mounted on the front panel and a power supply/output amp board mounted on the rear panel. The power transformer is mounted on the floor of the amp cabinet.
          I removed the back panel expecting to see a populated board minus output transistors. Boy was I surprised! Instead, I saw the power switch, fuse and wall wart power supply mounted with steel pluming pipe hanger tape. If the wall wart slips out it either shorts and sends line voltage across the back panel or flops around inside shorting out other components .
          A non-Peavey power amp was mounted on the floor of the amp cabinet.​
            Is that a trash can it is being prepped for?
              It's actually a horse trough planter. ;-)
              Yeah I'm not sure what to do with this amp. Probably sell it for parts.
                I'd guess those metal knobs are getting hard to find, and may be the most valuable parts there.
                  Weird!
                  I know Greg Ginn from Black Flag used one of these as his guitar amp for a while, so maybe there's still some mojo in the preamp sound. Wild that the power amp module was removed
                    Yeah. It probably took more time to mess around wiring the new amp than it did to find a correct board/back panel and get it working. BTW, since the cord was cut I never bothered to power it up to see if it works. My guess is no.
                      It's nice to see that you have "gifted" people too.
